Has anyone talked to Rivian about access to 12v for aftermarket accessories?
1) In addition to the Ham Radio inquiry in another post, I see need for interior 12v power in 'on' and also in 'accessory' power settings for devices such as a Radar Detector
, Public Services radio scanner, or similar devices.
2) I will want access to switched 12vdc for off-road lights in the front.. And since this is a software controlled vehicle, I would very much like to see the ability (maybe in a customization/settings menu?) to 'add' a on-off light function in the center control panel that controls one or more 12vdc relays located in the Frunk. At the very least, a 12v digital control line could be provided that allows for a standard automotive relay harness to be installed that then controls higher current exterior lighting.
Thoughts?
Thoughts?
