1 - 5 of 5 Posts
What happens if you get a second Rivian? How does the phone key handle that? My wife is due to get an R1S this year. I have an R1T.
Rivian needs to sell a license plate frame. I bought one on ebay and it really doesn't fit well (2 holes and the screws are too big for the screw cover, sticker tags are covered up). I ended up buying a generic one from WeatherTech.
The app supports multiple vehicles. You can swap between them in the app, same as how you can see the Wall EVSE in addition to your vehicle, if you have both.
I suppose if you have proximity (un)lock enabled and both are parked next to each other, you'll probably see both unlock when you approach.
Agreed.
Discussion Starter · #3 ·
Thanks!
I turned the proximity lock off at home. After 1 day, the novelty became a nuisance. Otherwise, I doubt we will ever be parked at the same place away from home.
A few other things - The app has a selector in the upper left corner to select your truck or your charger. After clicking the selector, there is a summary screen that shows Vehicles and gear, and that screen gives you the truck picture, model, range in miles, battery percent and VIN. For the charger, it just shows status. It'll say "Ready" when idle, or "Charging" when charging. After selecting a vehicle, the screen is the same as a single vehicle. All the controls, location, etc are all the same. When doing a 'Send To.... Rivian" in Android (e.g. to send a map location to the navigation) you get to pick which vehicle you send the information to. HTH and congrats on the pair of Rivians!
1 - 5 of 5 Posts
