A Black Friday sale, Emporia 48 amp charger 399….
I really see no reason to buy any third party chargers. I have the Rivian 48A wall charger installed and we have a second 32A Siemens that I purchased for another EV that we've since sold. Now we charge our R1T and Tesla Y using these 2 chargers. We are always adjusting the charge rate and schedule based on available home battery and solar resource and utility peak/off-peak times, and it's great that both Rivian and Tesla allows you to set up charge schedule and adjust charging speed. Tesla lets you do everything from the mobile app while Rivian only allows you to set charge limit and start/stop from the app, while you would need to change charging speed from the vehicle.I am getting my Rivian and want to know if I should go with their charger or is there a better 3rd party unit on the market. Happy to hardwire. I have a 60 amp circuit already wired waiting. I will be charging a tesla also and who knows what in the future. Thanks
I have same charger at 11.3kw. it works well and the cord is better than all the chargers I had before....plus longer tooA Black Friday sale, Emporia 48 amp charger 399….
Do your own, we own a Polestar 2 and a Rivian RT1 and we put our own socket in from our box with store bought Pipe cable circuit and outlet, we had an electrician install it in 15 mins and it cost total of $320 and all items from Home Depot, no issues for 7 months and the cars software will control power and times automatically. The Rivian is fantastic and enjoy the wonder of this great truck.I am getting my Rivian and want to know if I should go with their charger or is there a better 3rd party unit on the market. Happy to hardwire. I have a 60 amp circuit already wired waiting. I will be charging a tesla also and who knows what in the future. Thanks
If you have access to a professional crimper you can change the Tesla plug on the Mobile Connector to a 32A J1772 plug. A suitable J1772 plug can be purchased for $50......So no, the Tesla Mobile Connector is not the extremely great bargain you make it out to be. It is one solution, and it's not a bad solution, but it is most certainly not the cheapest solution and probably not the best solution for the OP unless there are other considerations that weren't mentioned.
I went with the Rivian charger due to the price point for a 48 amp wifi charger. Works well uses the Rivian app to see the charging logs. My only complaint would be the charge cord is very bulky, almost double the size of a charge point charger which was my second choice. CP charger is about 40% high in cost than the Rivian unit. Hope that helps.I am getting my Rivian and want to know if I should go with their charger or is there a better 3rd party unit on the market. Happy to hardwire. I have a 60 amp circuit already wired waiting. I will be charging a tesla also and who knows what in the future. Thanks
The Tesla Gen 3 Wall Connector with J1772 lets you connect multiple units off of one circuit. The Tesla Gen 2 charger (with Tesla plug) allowed up to four units. I think the Tesla Gen 3 EVSE can support up to 16 units on one 60 Amp circuit. At $550 the Tesla Gen 3 EVSE is an economical and elegant solution.....as far as I know, well boxes, the only EV charging unit on the market, and I am in the industry that offers the ability to put two charging units in line with one another. What that basically means is that they are running in parallel and sharing one breaker. This allows you to charge two vehicles off of one breaker, and they have the intelligence to throttle the amperage between two vehicles, sharing one breaker and pushing power back to one vehicle when the other one is done charging.
The benefits of this is that it can save some people thousands of dollars by avoiding the need to do a main panel upgrade to add a second breaker to accommodate the second charger
For those who are extravagant and want the best of the best at some point in Q1 they will be releasing their quasar unit which is a bidirectional unit a retail cost of about $4000
all Rivians are already built with the hardware capable of doing bi directional. It’s just a matter of them opening up the software through an OTA. This would allow you to use your 130KWH vehicle battery as a back up for your home in case of a power outage
If you only have one connection, you might want to get chargers that can share the line: i.e., charge both vehicles at 50% max. When one vehicle is done, the other gets the full load. Wallbox and JuiceBox do this. You may also want to check out the State of Charge channel on YouTube. The host has a lot of reviews on chargers.I am getting my Rivian and want to know if I should go with their charger or is there a better 3rd party unit on the market. Happy to hardwire. I have a 60 amp circuit already wired waiting. I will be charging a tesla also and who knows what in the future. Thanks
If you only have one connection, you might want to get chargers that can share the line: i.e., charge both vehicles at 50% max. When one vehicle is done, the other gets the full load. Wallbox and JuiceBox does this. You may also want to check out the State of Charge channel on YouTube. The host has a lot of reviews on chargers.I am getting my Rivian and want to know if I should go with their charger or is there a better 3rd party unit on the market. Happy to hardwire. I have a 60 amp circuit already wired waiting. I will be charging a tesla also and who knows what in the future. Thanks
