Do you want a truck that does 0-60 MPH in 3.1 seconds????. Well, then you need some big ass brakes to slow it down. Hence, why it has larger brakes than a Ford Raptor, which is able to get 18 inch wheels on them. Sacrifices have to be made for some of the benefits you get. Wheel size seems like a pretty minor sacrifice for all that the Rivian is otherwise.
0-60 times has nothing to do with brake demand or stopping distance…. It takes the same amount of power to stop a truck from 60 mph that did 0-60 in 2 seconds vs one that did 0-60 in 12 seconds. If they were really concerned with the shortest stopping distances why did they go with relatively skinny 275’s?
Super duty trucks that weight 8-9k lbs and to can have payloads in the 18k lbs run 15” brake rotors.
Heck, F1 cars have <11” rotors.
I’d also make the argument that EVs with regen when compared to a similar ICE could get away with smaller brakes due to the additional brake force from regen. I almost never use much pressure on the conventional brakes in my Teslas, even in the winter when I have regen set to low.
Larger rims increase braking distance, increase acceleration rate, decrease ride compliance and are very detrimental off road.
There will be more performance detriments from larger rims then gained from larger brakes.
And you can put 17’s on f150 Raptors.
