Got my R1T I;September and have put 6;000 miles on it so far. The EA and Rivian issues are real. I have owned a model X since 2016 so familiar with Evs and road trips. My take- Tesla is like Mac ( the software and hardware made by same people so it works well). Rivian is Windows ( hardware and softwre issues. Buggy software. Minor issues)
key issues
- handle locations don’t always line up with charge port. some stations I have had to park in one stall and use the charger on the adjacent stall as it is only one that will fit. Less of an issue when chargers are empty.
- handshake- the chrger and authentication is often times an issue. I have tried starting session on app and then plugging in handle, plug in handle and then start session on app, plug in handle and then use nfc reader, give up and use credit card. Sometimes it just works great. Sometimes it doesn’t. There is little rhyme or reason why as far as I can tell.
- I have had several issues where you plug in and the charger tells you to plug in. The charger does not recognize that the car is plugged in. the charge port makes a noise when it recognizes the charger. If it doesn’t make that noise you will not start a session. Period.
- speeds- The car does try to warm the battery for fast charging if you navigate to it. This appears to be more hit and miss. Doesn’t always work.
my Charging past few weeks. These are when it was on my account. If I gave up and used credit card it isn’t on here . If EA threw a complimentary session it isn’t in here either.
EA Springfield,IL - 16 min. 48 KWH. 209 kw max
EA Lebanon, MO. 10 min. 22KWH. 144 kw max
EA Mount Vernon, MO 13 min 43 kWh. 209 max
EA Mount Vernon, MO. 10 min. 25 kWh. 190 max ( previous session had error and ended)
EA Vinita,OK. 2 min. 6kwh. 212 max ( session fault and then couldn’t get it to work with app so used credit card)
Bristow,ok. 10 min. 18kwh 202 max. ( session issue same as above)
Weatherford,OK. 19 min 49 kWh 156kw max
Erick,OK. 24 min 71kwh 206 max
Amarillo,TX. 31 min 81 kWh. 210 Max
Tucumcari,NM 14 min 42kwh. 207 kw max
Pueblo,CO. 9 min 21kwh. 181 kw max
Colby,KS. 25 min 65kwn. 191 max
Lexington,NE. 41 min 97 Kwh 198 kw max
Lincoln, NE. 43 min. 95kwh. 206 Max
Council bluffs, IA. 9 min 22kwn. 205 max
Willimsburg,IA. 12 min. 33kwh 194 max
When it works it is fast and easy. BTW I would say at 80% of these session I was the only car there.
