What does the front of the spoke look like? He mentioned two wheels that look similar 2363 and 2495, but 2495 had an issue with clearance. The spokes look much thicker.
2363
2495
I went out and put one of the 2363s on my truck. You can see here there is no issue at all with brake clearance, over 9/16 of an inch.
Now that I have the 5 I wanted, I am going to have them stripped and coated in gloss graphite black Cerakote (color shown here with a gloss top coat).
I am going with the OE Pirelli tire, but in 275/60R20 so I don't have to mess with having it reprogrammed. If they change the system to allow the user to select tire size, I may go with the stock size, but probably not, the 60 is much cheaper, and only slightly lower in load rating, but still well above the axle limits.
The last piece of my setup is getting TPMS. I will work on that while my friend is coating the wheels.
