The R1S has a split rear hatch (Probably 75% top and 25% bottom., the upper portion is power open and close. The lower portion is manual.I need some help settling an argument with a friend of mine. Does the R1S come with a power rear hatch window? I haven't seen anything to suggest that it does but my friend is adamant that it does just like a 4Runner.
OP was asking about the WINDOW -- not the hatch.The R1S has a split rear hatch (Probably 75% top and 25% bottom., the upper portion is power open and close. The lower portion is manual.
No, I have seen no indication that the window is anything other than fixed glass.
That's what I figured, thanks for the help guys.I don't think so unless they have changed something or will change something between now and production deliveries. Power window would be cool but even if it just manually flipped open (like the Highlander) that would be awesome. Its a pain to have to open the hatch just to grab or put something quick.
I don’t want to say they are wrong but none of that makes sense.This is the response I got from Rivian:
"The rear hatch glass does open, but is a split window so openly opens up. It is not powered nor does it roll up or down like the video you attached." (I linked the 4Runner video) "So there is a door and window, that's why it's split. You have to open the bottom rear door to open the back window."
Agree. I think CS is talking about the entire upper liftgate, not just the glass.I don’t want to say they are wrong but none of that makes sense.
It may open but I have never seen it open and certainly does not look like it opens. It makes even less sense that you would have to open the bottom portion of the split hatch to open the top. Seems completely backwards to me and would render the power rear hatch unusable unless you manually opened the bottom section.
Agree completely. The split rear opening is not uncommon - I have that arrangement on my 2008 XC-90. On my Volvo, and every other car I've ever seen with the feature, you need to open the upper section before you can release the lower. There is no benefit to a reverse arrangement, at least not one that's obvious.I don’t want to say they are wrong but none of that makes sense.
Agreed.I don’t want to say they are wrong but none of that makes sense.
I’m getting the truck vs. the SUV, but I really like the power roll down window in my 4Runner. It’s especially nice when you want to ride with the windows open since it allows air to pass through the cabin vs circulating inside of it and being super noisy. Just have to be aware of any papers or light objects that might blow out!Agreed.
It wasn't a great response, especially with the 4Runner video that makes it clear what exactly the question is about. I take it that they have limited automotive knowledge, if that.
How would everyone here prefer to have the window open if Rivian does it with a future year model?
IMO, a completely motorized setup that rolls down/up is best.
If they could make the solid rear window roll all the way down, without affecting the gear tunnel, bed space, or interior space, then that'd be great... But if it compromises any of those features I'd rather it remain a solid piece of fixed glass.How would everyone here prefer to have the window open if Rivian does it with a future year model?
I hope that happens. It will be interesting to see what can be added in the future and if Rivian built some areas with obvious signs of future considerations.If they could make the solid rear window roll all the way down, without affecting the gear tunnel, bed space, or interior space, then that'd be great... But if it compromises any of those features I'd rather it remain a solid piece of fixed glass.
My 2019 Yukon (sold in this highly inflated pre-owned market) had a power lift gate in the back. If desired, one can manually open the window only like a hatch with the liftgate closed. This would allow reaching in and grabbing or placing an item in the storage location. I assume that the R1S would have something similar even if manually operated.This is the response I got from Rivian:
