You do a long press on the left/right buttons on the left side of the steering wheel to cycle through map, tire pressure, and efficiency.The driver display now shows my tire pressure on the left side at all times. It used to display the directions when the map was being used. I cannot figure out how to update the drivers display. Any help would be appreciated.
Do a short press on the same buttons to change your music.You do a long press on the left/right buttons on the left side of the steering wheel to cycle through map, tire pressure, and efficiency.
It took me a while to figure that out, too!
Thank you!You do a long press on the left/right buttons on the left side of the steering wheel to cycle through map, tire pressure, and efficiency.
