In anticipation of a long-distance trip I thought I'd try out a Level 3 charger. Went to a local EVgo station and pulled into a spot and waited a couple of minutes while another vehicle was finishing up. Although the charger seemed to be working fine, I couldn't get an actual charge started. I tried three times. Each time the vehicle simply said, "starting," but never actually began charging. Yes, I jiggled the handle to ensure it was correctly connected to the car.
Called EVgo and they reset the machine. Still nothing. Called Rivian and reset the R1T. Still nothing. I learned that if you get three charging failures in a row your car goes into failsafe mode and you've got to do a reset.
I've seen this level 3 issue pop up a tiny bit on the forums and so I'm curious about the diagnosis. The Rivian charging desk put in a trouble ticket but the service center is backed up so I'm not sure how quick they'll get to it. We shall see.
