As far as specs go, here's how the Bronco compares to the R1T
Bronco 4-Door
Wheelbase:
116.1 inches
Length:
Base: 189.4 inches
Height:
Base: 73.0 inches (soft top)
Width (with mirrors folded):
Base: 75.9 inches
Track Width (Front/Rear):
Base 65.0 inches / 65.0 inches
Off Road:
Ground clearance: 8.3 inches / 11.5 inches (Base/35 inch tires)
Suspension travel front/rear: 200 mm / 215 mm (Base)
Approach angle: 35.5 degrees / 43.2 degrees (Base/35 inch tires)
Breakover angle: 20.0 degrees / 26.3 degrees (Base/35 inch tires)
Departure angle: 29.7 degrees / 37.0 degrees (Base/35 inch tires)
Maximum Water Fording: 33.5 inches
Rivian R1T
Wheelbase
135.8 inches
Length
217.1 inches
Height
70.8 inches
Width
79.3 inches
Track (front/rear)
67.3 inches
Off Road
Ground Clearance: 14.5 inches (275/65R20 Tire)
Approach Angle: 34.8 degrees
Departure Angle: 30.5 degrees
Breakover Angle: 25.7 degrees
Maximum Water Fording: 42.7 inches
