For those of you with a hitch mounted bike carrier you may want to read this thread.
I have a RockyMounts Backstage. When I connected it to the R1T the hitch bolt was too short to lock. It also did not engage the anti-sway mechanism. Contacted RockyMounts and the solution was to grind down the lock from 36mm to about 34mm and now problem solved.
Don’t waste $ on Thule Snug Tite 2 - didn’t work.
