Offer them yours for free cover.Rivian won’t be able to get them a truck to test fit it until sometime in late 2023.
If Rivian would deliver me a truck I’d be happy to!Why not use a customer truck? That seems to be how most other aftermarket companies do their R&D.
They did not say but mine is around 9800 and it apparently V2And at have vin did they cut in v2???
Interesting… mine is 991x and works okay. Dry lubed and all. And you think ours has two motors? Would love to check that. Can the top plastic cover be easily removed for a looksie?They did not say but mine is around 9800 and it apparently V2
That is news. I was told the power tonneau would not be an option for trucks shipped without one since the rails wouldn't be included.I received delivery on Saturday with no tonneau at all. Yesterday I talked to Rivian on the phone and they said when a new design is out early next year, they will install a new powered tonneau.
That's great, I'm really hoping to get my fix soon since I carry stuff in the bed for work every day. Hurry up Rivian!!!!The new redesign is already out. My original one broke the second day which was very upsetting, but 4 weeks later they called as they had received one of 30 in the nation and wanted to install on my truck. I’ve had it for over a month now and it works great. It is also a bit quieter. I will assume the mechanism inside is different but outside the only noticeable thing is that the slats overlap instead of butting end to end. The other thing is that when it retracts it sticks out just a touch so the last slat does not go in. I assume this is so it doesn’t completely detach which is why they’re having many of them break.
All that being said, I am not clear whether they are offering this to everyone or just to those that are broken.
The email they sent about it says:That is news. I was told the power tonneau would not be an option for trucks shipped without one since the rails wouldn't be included.
I had a manual Retrax that I had on two different Tundra 1794's. The dealer didn't want it when I traded. Zero problems...BUT (and it's a big but)...the rolled up cover from "only" a 5-1/2' and the box it rolled into takes up an inordinate amount of room. There are also two drain hoses to be routed (through the bed wall in front) to let out the water that finds its way into the box. Even though there would be less "rolled up" (since the bed is a foot shorter), there would be hardly any room left in the bed. I wouldn't go the Retrax route on a Rivian. The other downside is heat. I live in South Texas and the unventilated sealed up bed with a black Retrax on it easily attained temperatures of over 130 degrees on 100+ degree days. I fried an egg on the surface of it to show that it could be done. I don't want to heat my battery pack "from above". The Rivian tonneau is "not waterproof" (and certainly nothing like "airtight"), whereas I never got any water in the bed with the Retrax...so...no ventilation was going on.Had a manual retrax on a F150 for 7 years with zero problems.
