Propane tank transport
603 Views 6 Replies 7 Participants Last post by  RITVT
Anyone come up with a clever/easy way to secure bbq propane tanks in their R1T? I stuck mine inside behind the drivers seat the other day and thought someone must have figured out a way to tie these down....
1 - 7 of 7 Posts
I lay mine on their side and position them in the "grooves", then anchor a strap on both tie down points and pull / tighten a strap across the bottles. Seems to work pretty well in an open bed.
  • Like
Reactions: 1
propane tank in milk crate in gear tunnel?
I have a strap that I put across the back from the tie points on both sides and adjust it with the tanks in there and tailgate up holding them to the rear of the truck. I keep that strap set at that position and use it every time I need to transport by hooking it on both sides, then slide the tanks in holding the strap up and push them in to hold the strap where it is. Then when I close the tailgate it puts just a little more tension on them. I have to charge 4-6 tanks 1-2x a week, so it's gotten pretty routine. My biggest gripe has been during the winter - I really wanted to close the tonneau. At least this way you can close it up to the upper part of the tank if you want. I got even tired of that and built a canopy to cover.
Thinking about it, one of those cargo nets from an SUV across the back would probably work pretty well.
Tire Wheel Automotive tail & brake light Car Vehicle
See less See more
  • Like
Reactions: 1
I find they fit perfectly in a milk crate. Then you can strap them into it and tie down the crate.
Is this for the range extender?
Whoa, you built that cap? Sweet!
  • Like
Reactions: 1
1 - 7 of 7 Posts
