This new patent from Rivian filed on March 29, 2022, shows a front bumper with a winch.
It must be powered from the main battery. The 12V battery is too tiny for a winch plus it is needed to keep the truck's brain alive.Too bad there aren't any images with the actual winch that we can see. Also, how would a winch be powered in the R1T? From the 12 volt battery?
Here's a prototype with it, definitely powered by the main battery.Too bad there aren't any images with the actual winch that we can see. Also, how would a winch be powered in the R1T? From the 12 volt battery?
What capacity does everyone think the factory winch will pull up to? Around 8,000 lbs at the lowest?
In comparison, I would use an 8000 on my jeep, which weighs less than half what the Rivian does. Apparently a good rule of thumb is at least 30% over your vehicles GVWR8000 would be way too little. I would say min 12000, and bigger if I can afford it, nice thing is, there are some interesting 400 Volt ones out there, so could certainly run off the main pack
