Thanks to the PowerFlex website, we now know that there are 13 Rivian charging stations that have been installed so far!
www.powerflex.com
Projects – PowerFlex
That was my guess on another forum, based on the background in the pictures, you can see palm trees.Some where I saw that it may be at Rivian's Irvine, CA office.
Rivian’s “adventure network” will consist of both DC fast charging along major highways that get people to State Parks and L2 chargers at trailheads.These are level 2 chargers, not the high speed DC chargers that will be on the RAN network. From the looks of it, likely at a Rivian office in CA. It’s likely a prototype for the Rivian EVSE that they will sell you to put at your home.
I think Rivian should contact the company called EV ARCThanks to the PowerFlex website, we now know that there are 13 Rivian charging stations that have been installed so far!
www.powerflex.com
View attachment 1031 View attachment 1032 View attachment 1033
Cool idea, but at 22 KWh of charge capacity per day and the Rivian getting about 2 miles per KWh (400 miles / 180 KWh) this thing is only good for putting a total of 40 miles of range charge per day for a Rivian. I don’t see it being a viable solution.I think Rivian should contact the company called EV ARC
These chargers are solar powered self contained units. They can literally get delivered with a flat bed tow truck and no electrical grid hookup needed. These would be perfect for trailheads and other remote locations.![]()
An Easy-to-Install Solar Charger That Juices Your EV Off the Grid
The first thing Desmond Wheatley tells me about his solar-powered EV car charging system is you don’t need great weather to make it work. “The highest concentration of photovoltaics anywhere in the world is in Germany,” he says. “The weather is appalling in Germany. Raining, cloudy and gray all...www.wired.com
I sure hope they don’t install a bunch of these and use that as a way to claim big numbers of charger installed and success. L2 charging is not the problem, nor the solution. It’s in parking lots and homes everywhere. In remote areas, all you need to do is find a campground and pay them to plug into a NEMA 14-50 RV outlet (which, btw is 50% faster than the J1772 chargers you find in parking lots). We need high speed DC chargers in areas that don’t have them. Including major interstates across the northern part of the country. Yes, a few L2 chargers at so,e major trailheads would be nice. But there’s no way they are going to be able to cover the thousands of major trailheads we have in this country. The right answer is high speed DC chargers on the routes leading to those trailheads.Rivian’s “adventure network” will consist of both DC fast charging along major highways that get people to State Parks and L2 chargers at trailheads.
From my understanding it's in Irvine. Makes sense since PowerFlex is also in California.Some where I saw that it may be at Rivian's Irvine, CA office.
Sorry for the ignorance, but is there a direct cable from NEMA 14-50 to the R1T? What is the purpose or need for the wall EVSE?I sure hope they don’t install a bunch of these and use that as a way to claim big numbers of charger installed and success. L2 charging is not the problem, nor the solution. It’s in parking lots and homes everywhere. In remote areas, all you need to do is find a campground and pay them to plug into a NEMA 14-50 RV outlet (which, btw is 50% faster than the J1772 chargers you find in parking lots). We need high speed DC chargers in areas that don’t have them. Including major interstates across the northern part of the country. Yes, a few L2 chargers at so,e major trailheads would be nice. But there’s no way they are going to be able to cover the thousands of major trailheads we have in this country. The right answer is high speed DC chargers on the routes leading to those trailheads.
My Tesla came with a cable that included several adapters. It has an adapter that plugs into a standard 110v wall outlet and another NEME 14-50. No EVSE needed. I’m just assuming that other EV’s have similar capabilities. Somehow the Tesla knows how much current to draw based on what adapter is connected I guess. Just plug it in and it works. Given these are supposedly high tech vehicles, I can’t image they wouldn’t have similar capabilities.Sorry for the ignorance, but is there a direct cable from NEMA 14-50 to the R1T? What is the purpose or need for the wall EVSE?
The brick you connect the adapter to is the EVSE.It has an adapter that plugs into a standard 110v wall outlet and another NEME 14-50. No EVSE needed.
It most likely adjusts the current based on the voltage input, not based on the connector itself. 12A for 120V and 32A or 40A for 240V.My Tesla came with a cable that included several adapters. It has an adapter that plugs into a standard 110v wall outlet and another NEME 14-50. No EVSE needed. I’m just assuming that other EV’s have similar capabilities. Somehow the Tesla knows how much current to draw based on what adapter is connected I guess. Just plug it in and it works. Given these are supposedly high tech vehicles, I can’t image they wouldn’t have similar capabilities.
This is correct. I haven’t used my charging cable in quite a while, but just checked and it has an inline brick that I can only assume provides the necessary circuitry to make it an EVSE. I forgot or never noticed that inline brick.The brick you connect the adapter to is the EVSE.
The only reason I can think of to keep the EVSE brick outboard is that it's a part with a higher failure rate and it'd be a lot cheaper to just buy a new brick and cable vs. having the vehicle serviced. It is something of a pain, as I never think to take it with me on my i3 and I don't need to on the road often enough to buy a $700 spare.This is correct. I haven’t used my charging cable in quite a while, but just checked and it has an inline brick that I can only assume provides the necessary circuitry to make it an EVSE. I forgot or never noticed that inline brick.
That being said, I would assume that Rivian would want to provide the ability to plug the truck into either a std 110v outlet or a NEMA 14-50 at campgrounds with RV hookups for emergency or totally out of the way charging. So wouldn’t they need to include something similar to what Tesla provides relative to a cable with portable EVSE? Or would they leave it to the aftermarket to produce something?
I’ll likely want something similar to what my Tesla has since I see the need to charge at RV parks until the Level 3 network is better built out. So I’d still opt for just putting a NEMA 14-50 outlet in my garage and then using the portable EVSE cable/charger into that vs. having two EVSE’s (one portable and one fixed).
