I didn't consider that but it makes a lot of sense. I checked on Rivian's website and there's a 14 inch wheelbase difference between the two.It most likely has to do with the wheelbase. I have an old Jeep TJ, it is rated at 2000 lbs, a Cherokee from the same year (same engine, axles everything) can tow 5000 lbs because it is much longer. Same deal here. I am sure someone can go into the physics of it, but that is the simplest answer.![]()
Towing update from the chat with them. Trailer Hitch is hidden behind removable panel. It is a 2'' Class V receiver. The R1T's towing capacity is 11,000 pounds and the R1S is 7,700 pounds. Also the trailer hitch receiver and vehicle structure are rated for a tongue weight of 810 lbs.I keep on looking and don't see any R1T with a hitch , does that mean truck doesn't come with it and you have to install it or its hidden?
Here's some screenshots from the Rivian hot weather testing video. You can see the R1T's trailer hitch. I imagine it will be the same for the R1S.I keep on looking and don't see any R1T with a hitch , does that mean truck doesn't come with it and you have to install it or its hidden?
Tongue weight for the R1T is 1470 lbs, not 801 lbs like the R1S.Towing update from the chat with them. Trailer Hitch is hidden behind removable panel. It is a 2'' Class V receiver. The R1T's towing capacity is 11,000 pounds and the R1S is 7,700 pounds. Also the trailer hitch receiver and vehicle structure are rated for a tongue weight of 810 lbs.
