When the Rivian R1T was first revealed it was said that it would come with a whopping 10,325 lb-ft torque. Now that would be some groundbreaking stuff but as we've seen from the electric Hummer, those torque numbers can be fudged a little bit.
When calculated in the more conventional way, the quad-motor R1T should produce 829 lb-ft of torque which is still a scary amount of power, especially when you consider that a 2020 F-150 produces 510 lb-ft of torque with the High-Output 3.5L EcoBoost V6
Personally I plan on testing the R1T's power off-road and in a straight line. But is anyone planning on using it as a work truck?
