In this towing test, the Rivian R1T lost nearly half its normal driving range, dropping from 314 miles to as low as 170 miles.
www.motortrend.com
"The Takeaway
Towing roughly 9,000 pounds with a Rivian R1T reduced our driving range by 45 percent on average, slightly better than Rivian's estimate of a 50 percent reduction when towing the maximum 11,000 pounds the truck is capable of. Our range dropped from an EPA-estimated 314 miles to as low as 170 miles. For context, that's 30 miles farther than a standard Nissan Leaf can cover on a single charge but less than most other EVs.
For more context, keep in mind your results will vary greatly for all the same reasons they would when towing with a gas- or diesel-powered truck. How far you'll make it on a charge will depend on the weight of your trailer, the shape of your trailer and any load it's carrying, the roads you drive on, the speeds you drive at, and how you drive. Our blocky old van sitting high on a flatbed trailer was an aerodynamic brick, but the majority of our route was a gradual descent from elevation.
Of course, your range is also a function of the public EV charging network. If needed, we could've stopped at a public DC fast charger and juiced up the truck and extended our range significantly. This option currently has drawbacks, though. Unlike gas pumps, EV chargers are almost never built for pull-through traffic, making it difficult to park a vehicle with a trailer at a charger without unhooking the trailer. Second, even the best DC fast charging is still slower than a gas pump. Rivian says you can add 140 miles of range in 20 minutes, and as with all EVs, charging isn't linear, so it'll take more than 20 minutes to add the next 140 miles of range. Regardless, figure an hour to stop and charge, all said and done.
Yes, you can absolutely tow with an electric truck, but at least in the case of the Rivian R1T, expect to lose up to half your driving range as you approach its maximum towing capability, much as you would in a gas- or diesel-powered truck. If you need to tow more than 150 miles, plan to hit a public charger along the way and give yourself ample time to fill up."
How Far Can You Tow With an Electric Truck?
We hitched a 9,000-pound trailer to a 2021 Rivian R1T EV pickup to find out how towing affects range.
