You'd think it would work for the R1T but I don't know if that's in the plans for Rivian. It could be an aftermarket thing potentially.Does anyone think that the R1T and/or the R1S will be able to be equipped with a snow plow? It seems like they'd be capable of doing it based on the specs. Plus it would be better than using a big gas/diesel pickup.
Quite some time ago I believe I had read Rivian had no plans for this. At any rate, that doesn't surprise me if you break it down to the vehicle's target segment - "adventure" not "utility." Pending snow conditions plowing could end being an adventureYou'd think it would work for the R1T but I don't know if that's in the plans for Rivian. It could be an aftermarket thing potentially.
That does seem to be a great marketing spin to this question, "Why plow snow, when you can go on a winter adventure!" I agree too with the warranty, Rivian is not going to want people screwing around with their stuff, especially this early on.Quite some time ago I believe I had read Rivian had no plans for this. At any rate, that doesn't surprise me if you break it down to the vehicle's target segment - "adventure" not "utility." Pending snow conditions plowing could end being an adventurebut more likely considered utility.
So IMHO I wouldn't hold your breath on Rivian providing any feature or support in this area, at least not initially. As for aftermarket, it will be interesting on how Rivian writes up their warranty if, say, modifying the front end for a plow would void the warranty. After all, I doubt they did any testing with either EAV with a plow attached to it.![]()
