I found these photos from the Long Way Up on Instagram, does this mean that the R1T and R1S are able to handle tow charging?
http://instagr.am/p/CFv9_5lgr7x/
Awesome, I'll check it out, thanks @Babbuino!Yes, Emme also mentioned tow charging in a podcast. Go to 1h 11min and they start talking about it.
Yeah. I guess the weight is one of the factors. The 135kwh version. Already weighs 5886lbs. Not sure how much more weight the 180kwh will add...10% charge in 6km of tow charging is impressive. I also didn't realize they're using the 135 kWh battery for the rally and not the big battery.
That's probably the reason. It also helps that the organizers designed the course for the R1T to compete.Yeah. I guess the weight is one of the factors. The 135kwh version. Already weighs 5886lbs. Not sure how much more weight the 180kwh will add...
I have to think so. I doubt tow charging would be the default. It's probably a special mode you have to put the truck in.So the tow charging works by adding drag to the tow vehicle, right? If you know that your destination will have charging, and you want max fuel economy from your tow vehicle, can you turn off the tow charging? For lack of a better term, can you put the Rivian in "neutral" so to speak so it is spinning freely and not adding as much drag to the tow vehicle?
Conservation of energy and all that...
From the way they describe it in the video there's no way you can do this safely on a public roadSo the tow charging works by adding drag to the tow vehicle, right? If you know that your destination will have charging, and you want max fuel economy from your tow vehicle, can you turn off the tow charging? For lack of a better term, can you put the Rivian in "neutral" so to speak so it is spinning freely and not adding as much drag to the tow vehicle?
Install a rigid tow bar and it is perfectly safe.From the way they describe it in the video there's no way you can do this safely on a public road
I would think "yes".So the tow charging works by adding drag to the tow vehicle, right? If you know that your destination will have charging, and you want max fuel economy from your tow vehicle, can you turn off the tow charging? For lack of a better term, can you put the Rivian in "neutral" so to speak so it is spinning freely and not adding as much drag to the tow vehicle?
Eventually we will be able to charge everywhereSo the tow charging works by adding drag to the tow vehicle, right? If you know that your destination will have charging, and you want max fuel economy from your tow vehicle, can you turn off the tow charging? For lack of a better term, can you put the Rivian in "neutral" so to speak so it is spinning freely and not adding as much drag to the tow vehicle?
