Amazon, https://a.co/d/hPRv2ckOh... Forgot to ask. Where did these center caps come from?
Do the OEM Dodge 2363 wheels have a tag or nameplate on the inside that calls out the model? Starting to browse local craigslist and FB market place ads which most don't call out the model, so hopefully there's a tag on the inside or some sort of distinguishable part number?Correction my wheels are Dodge OEM 2363 which are 20x8 5 x 5.5 with 18mm + offset. The 2606/16 appear to be similar spec. The mistake I made initially was I ordered a set of aftermarket wheels on ebay with the similar specs and they did not fit due to caliper rub. For any aftermarket wheel, I would suggest ordering one wheel and test fit on the front before ordering the rest of the set.... It cost me $250 so ship back my assumption. The 2363 do fit with no spacers and I used my Rivian lug nuts.
Not that I am aware of, but this is the style...Do the OEM Dodge 2363 wheels have a tag or nameplate on the inside that calls out the model? Starting to browse local craigslist and FB market place ads which most don't call out the model, so hopefully there's a tag on the inside or some sort of distinguishable part number?
I don't believe anything in the wheels identifies them (mine are being coated so I can't check now). You just need to look at the spokes, the 2363 is more flat, and the spokes are thin, the 2495 has a slightly rounded, but thicker overall profile to the spoke.Do the OEM Dodge 2363 wheels have a tag or nameplate on the inside that calls out the model? Starting to browse local craigslist and FB market place ads which most don't call out the model, so hopefully there's a tag on the inside or some sort of distinguishable part number?
It's likely mostly due to the tire difference between an all-terrain and a street tire. The 21's do sit inward some as compared to an 18mm offset custom wheel and more so than the stock 20" wheels, so there is likely some minor impact as a result of aero as well, but minimal. Unfortunately, for now at least, truck tires for a 21" wheel are quite limited.With such a minor offset, I would assume the decrease in efficiency is mostly the tire choice, no? Obviously an AT with more aggressive tread will get worse than the 21 Scorpion that is more road oriented. I do like the look of the 21s when blacked out. Its too bad there isnt an AT in the 21 size. That would be the easieset option.
That's a nice cost savings from what I paid. Guess enough people ordered for them to be added as a standard size.An update on the hub centric rings: Wheel connect now carries them as a stock size.
https://www.amazon.com/dp/B0BHR5FHP2?ref=myi_title_dp
They have a few that match up to the Rivian, however, all depends on specifically which custom wheel you get. I checked to see if there were any that would work with my wheels and there were not. Great price if they do match up to your custom wheel. All depends on the bore size of the custom wheel, which seems to vary from wheel to wheel, even those sold by the same manufacturer.An update on the hub centric rings: Wheel connect now carries them as a stock size.
I haven't looked at these, but not all 20mm offset wheels clear the brake calipers. So beware. I purchased a set that I ended up selling because they didn't fit. 20x9 20mm offset. Each wheel is cut differently, so it's possible not all 18mm offset wheels would clear either. That's what I have now and the set I have does clear. But, that doesn't mean they all will.For ideas...here are all the BlackRhino Wheels that I can find that would fit (20x9 with +20 offset):
Right. These are the ones specifically for the Dodge wheels mentioned in FirstStateR1t's posts. They were a custom order but now are standard. The same vendor will do any custom size you need, I think for around $40 a set.They have a few that match up to the Rivian, however, all depends on specifically which custom wheel you get. I checked to see if there were any that would work with my wheels and there were not. Great price if they do match up to your custom wheel. All depends on the bore size of the custom wheel, which seems to vary from wheel to wheel, even those sold by the same manufacturer.
And this is why I built my budget 20" AT setup...By the way, did y'all notice that the 20" AT shell/tire sets have gone up to $4,100 in the Rivian Gear Shop? They were $3,100, right (or am I gaslighting myself)?
