Rivian DCFC Hardware System
Key features:
- CCS connector
- 300 kW chargers capable of output voltages up to 920V
- Energy efficient design via custom-developed silicon carbide power electronics
- Cloud-connected automated diagnostics
- Mobile app provides property location and GPS navigation to charger, charger status, and notifications
- Over-the-air updatable firmware
- ADA compliant
- UL certification pending
Preliminary technical specs
Nominal input:
- Phases/Lines: 3 lines
- Voltage: 480V
- Frequency: 60 Hz
- Power Factor: 0.99
- Efficiency @ full power: >94%
DC output:
- Voltage range: 200-920V
- Dispense power: 500A
- Power (peak/continuous): 300 kW/300kW
Target dimensions (H x D x W):
- Dispenser: 1,778 x 572 x 356 mm
- Power cabinet: 2,286 x 1,219 x 1,219 mm
Ingress protection: IP 55, outdoor use
Operating temperature: -35 degrees celsius to 55 degrees celsius
Vehicle communication: IEC 61851-23PLC (CCS / Combo-1)
Network connections: 4G LTE
Rivian AC Hardware System
Key features:
- Charge speed: 11.5 kW chargers compared to common 6.8 or 7.2 kW variants
- Design: Aesthetic exterior design and SAE J1772 plug provides maximum compatibility
- Power balancing: Control via Rivian-developed software maximizes charging within existing utility infrastructure
- Dashboard: Remotely view and control stations settings via a Rivian-developed site host dashboard
- Plug & charge: Seamlessly plug and process payment through ISO 15118 or Rivian's network
- Mobile app: Provides property location and GPS navigation to the charger, charger status, and notifications
- Connected unit: Allows over-the-air updates to firmware
- Digital readout: Provides a user-friendly way to communicate time of sale information
- ADA compliant
Nominal input:
- Input power connection: 60A
- Input current: 48A
- Voltage: Single phase 208 / 240V AC
- Frequency: 60 Hz
- Power factor: 99%
- Efficiency: Energy Star Certified
- Pedestal conduit window: 12" by 12"
AC output:
- Standard electrical output: 11.5 kW (240V AC @ 48A)
- Dispenser: 413.5 x 143.5 x 196.85 mm
Other specification:
- Connector type: SAE J1772 type 1 (NA)
- Ingress protection: IP 54, NEMA 3R, outdoor use
- Operating temperature: -35 degrees celsius to +50 degrees celsius
- Vehicle communication: SAE J1772 / ISO 15118
- Local area network: 2.4/5 GHz Wi-Fi (802.11 a/b/g/n)
- Network communication: 4G LTE, RJ45 ethernet 100BASE-T
