Xtrusion Overland has finalized its design and is excited to bring their XTR bed racks to the R1T! With innovative attachment methods and bed rail mounts that will not require any modifications to your Rivian, the XTR family of bed racks are a perfect solution for the R1T. Manufactured here in the US, all with aerospace grade components, gives you unparalleled weight to load rating ratios.
Get all the versatility of the original XTR1/3 bed racks and configure it however to suit your needs! Nothing else in the market comes close to this much versatility. Select between the XBRS low height options, or up to a cab height with the XTR1 or XTR3 configuration. All lengths are at 48” from front to back. All accessories and many substructures from the Xtrusion Overland catalog will be compatible including the Modular Molle plates, aXs gates, Side slide outs, Tent Brackets, Hi Lift mounts and many more!
The R1T required us to think outside the box. The R1T version of our bed racks will feature an innovative bed rail mount that attaches a section of aluminum t-slot with rubber on the bottom side to avoid wear on your bed rails. The t-slot rail will attach to the OEM bar clamping system and with a mechanical button to pass through to the gear tunnel switch.
With a completely new Billet CNC machined aluminum bed rail bracket system that will match the premium look and feel that Rivian demands.
Also included is our new Billet CNC machined Side and Top Brace mounting system, to create unparalleled rigidity on the already stout platform that is the XTR bed rack. This will allow you to mount at the distances that make sense for your build.
Light weight with its ALL ALUMINUM construction with black texture powder coat and black anodized brackets, superior to any sheet metal rack!
Get ready to pre-order Monday, January 30th, midnight CST limited to 50 pre-release racks and deliveries starting March 15th. Starting at $1800 for XTR1 (4 uprights, 2 crossbars from 10 to 22” in height) and $900 for XBRS (2 Crossbar Sets from 5” to 8”) and $2500 for XTR3 (6 uprights and 3 crossbars from 10” to 22” in height).
