I had an issue in cold weather with the under bed storage. In freezing conditions, you may not be able to access this area. I have tire chains and a tow strap stored there. When I needed the strap, the latching mechanism was frozen shut, and there was absolutely no way to open it. Apparently water got into the mechanism and then froze. Don't store anything you might need on the road there as you may not be able to access it until you are back in a heated garage.
