You can do this via the smartphone app.
There is no feature that automatically vents your windows. You can Vent/Close the windows via the app or the key fob.I might be dreaming this, but I left R1T outside on a sunny 75 degree day. When I went out to truck a few hours later all 4 windows were lowered an inch or two.
Question- Is there a setting that allows this to happen? If so, can it be over-ridden?
It is equipped with a vent option from your phone app to open and to closeI might be dreaming this, but I left R1T outside on a sunny 75 degree day. When I went out to truck a few hours later all 4 windows were lowered an inch or two.
There is also another way to operate the windows. i've done this a couple of times but can't seem to get IT done again.by holding down the lock and unlock buttons at the same time for a few seconds, all four windows will open all the way. and if you do the same thing they will all close.I might be dreaming this, but I left R1T outside on a sunny 75 degree day. When I went out to truck a few hours later all 4 windows were lowered an inch or two.
Not quite. You don't hold both lock and unlock... You press unlock once then push again and HOLD.There is also another way to operate the windows. i've done this a couple of times but can't seem to get IT done again.by holding down the lock and unlock buttons at the same time for a few seconds, all four windows will open all the way. and if you do the same thing they will all close.
any confirmation would be appreciated
I’m sure this works but it’s not. Maybe I have something set on the main screen I need to change???Not quite. You don't hold both lock and unlock... You press unlock once then push again and HOLD.
And that button says "Vent Windows' when they are up! Use it every day.What?!? I don't think that is feature... If it is a feature, there should be an alert in the app before opening occurs, and then you should have to "agree to crack windows". I think it would be an awesome feature, but I either didn't know that existed, or it doesn't.
I use the app to close windows that were left open all the time though...
