Does anyone have any information regarding Rivian’s charging infrastructure Plan? Will they have the infrastructure in place by the time vehicles are delivered?
Direct from RivianDoes anyone have any information regarding Rivian’s charging infrastructure Plan? Will they have the infrastructure in place by the time vehicles are delivered?
Will they increase the level 2 spec to handle faster charging? Tesla's previous generation chargers could support up to a 100 amp breaker, the newer wall chargers are less now. But from what I can tell the max a level 2 charger can handle is a 40 amp breaker - that means 32 amps = 7680watts. With a 180kwh battery - could be more than just overnight to charge (at home...)...Level 2 will be a a SAE J1772 and DC will be CCS. Both standard. Many chargers out there that will work just as Tesla does. Rivian may have on to buy. This site is a start to learn the specifics. Lots of info out there.
Top 10 Best Home EV Chargers, 2020 - AutoGuide.com
If you live in an area with underdeveloped infrastructure, there's a good chance you're going to have to install a home EV charger.www.autoguide.com
I would think that would only be an issue if you go from 0 to 100% SOC, which is not recommended on a regular basis. I've seen (in general, not Rivian) a recommended SOC range is 10 or 20% to 85 or 90% to prolong battery life. So that's about 70% of the 180 kWh BP = 126 kWh. Dividing that by 11.5 kW would take just under 11 hrs to charge, but that doesn't account for any factors like taper. Not known at this point if Rivian will taper the charge as the BP reaches higher % of SOC, but I suspect they will, meaning the tail-end of charging may take a little longer to charge.With a 180kwh battery - could be more than just overnight to charge (at home...)
Yes, OK, I put a 60 amp breaker on my current charger. (Tesla) I haven't seen any of the current non-tesla chargers go beyond 40 amps...Rivian R1T and R1S will have a 11.5 kw onboard charger. At 240 volts the most it will draw is 48 amps (11500 w / 240 v) which requires a 60 amp breaker and the EVSE hard-wired vs plugged in (e.g. into a NEMA 14-50R). It's my understanding that anything bigger than a 60 amp breaker is not necessary unless you're looking to future proof your set up, say, for a future EV with a more powerful onboard charger and/or a second EV you'll be charging. BTW, Wattzilla brand makes EVSEs from 40 to 80 amps.
So far Rivian has given no indication they will go with a more powerful onboard charger at least with the introductory models.
Awesome - thank you - I hadn't seen any of the chargers that would be able to provide full-charging amps...Rivian is supposedly going to 11kw for level 2 charging which would require a 60 Amp box and must be hard wired. Check juice box.
Next Gen JuiceBox 48 Amp Car Charger with WiFi | Enel X
The NEW JuiceBox 48 amp WiFi-connected electric home electric vehicle charger — the even faster way to charge your Tesla and high performance EVs at home. Shop now!evcharging.enelx.com
Just so you are clear the charging station is not a charger unless you are DC fast charging. Level 1 and level 2 chargers are built into every EV car or truck. The cord you attach is an EVSE short for electric vehicle service equipment. Basically a smart cord that checks for faults and proper electricity before allowing current to flow. With the ability to make the live end dead so there is no chance of an arc or anyone touching a live circuit. I hope you find this info informative.Yes, OK, I put a 60 amp breaker on my current charger. (Tesla) I haven't seen any of the current non-tesla chargers go beyond 40 amps...
Good point on the SOC, 11 hours is double what I am doing now - but the capacity is double too!
Thanks for your help.
GEON
Appreciate the correction, but who cares? This what powers the charging of my vehicle. My point was that the Tesla unit can have a variety of breakers in it and participates with the charging amperage flow.Just so you are clear the charging station is not a charger unless you are DC fast charging. Level 1 and level 2 chargers are built into every EV car or truck. The cord you attach is an EVSE short for electric vehicle service equipment. Basically a smart cord that checks for faults and proper electricity before allowing current to flow. With the ability to make the live end dead so there is no chance of an arc or anyone touching a live circuit. I hope you find this info informative.
The charging port is at the front so the trailer should be able to remain connected. In some urban areas, the size of the parking area may be the limiting factor.I would acquire an R1S and use it to tow a trailer for long distance trips. I will expect to stop to charge about every 200 miles even with the 180 kWh battery pack.
Does anyone know how this will work at charging stations with a trailer attached? Will there be drive through charging stations that will accommodate a trailer? Might not be easy if a 40’ trailer had to be disconnected for each charge!
Complete newbie here to EVs. Read all the replies here and have no idea what you're talking about. What do I need at home to charge this vehicle. Pretend you are explaining it to a 10yr old. I have never owned an EV. Don't know what I need, where to get it, or who I need to have install it, or if the electric panel on my home is even sufficient.Hiya!
Just joined.
Does anyone know what charge plug the Rivian plans to use? Will they make a "wall" charger like Tesla does, for home charging?
Thanks,
GEON
BTW, I wonder if they'll provide that service...@Babbuino Great post, thanks.
@barkway Before the Rivian arrives at your house, you can get the charging station installed. Buy one of the reputable ones, like this JuiceBox (linked), call your local electrician, and tell him you want to install a charging station. Your electrician will sort out whatever needs to be done at your home. Electricians everywhere have been installing these for years now and will know what to do.
That's all there is to it. Your home will now be ready to charge the Rivian or any other EV you buy.
I'm sure one of the charger manufacturers would love to make one for Rivian and put Rivian's name on it. I have a ClipperCreek 50 AMP and I'm sure they make others.BTW, I wonder if they'll provide that service...
Seems to me that offering rebranded chargers + partnering with an installation provider would be both 1) a profit center for Rivian and 2) a way for Rivian to ensure customers are receiving consistent experiences getting their homes setup, which can be confusing for many peopleBTW, I wonder if they'll provide that service...
