Wondering if I can use my Rivian wall charger on a hybrid vehicle (specifically, a 2022 Volvo XC90 hybrid)? Thanks in advance for any help you can provide!
Can't see any reason why you couldn't. As long as the car uses the same connector, it will work. Go for it. It's a great charger since it also does 220 volts.
Can't see any reason why you couldn't. As long as the car uses the sane connector, it will work. Go for it. It's a great charger since it also does 220 volts.
